I bought a PC-8 fuse panel and today - while it rains- I took off the tupperware and have been getting my first look under the skin at what I got- so far so good.
Here's my question- Where to draw switched power from? I see the Spyder fusebox in the trunk has an open spot for a 3a fuse and it is labeled "accessories". I popped the fuse box out and it looks like the purple wire will be switched if I put a fuse in place...is that right?
3a should be fine to power my accessory relay so can I tap off the purple wire and be done with it?
thanks in advance for any help.
