cognaccruiser
I am in the process of replacing my windshield arm and have run into a small problem. Before it gets to be a big problem I thought I would ask for some thoughts.
I'm at the point of taking off the screws from the pieces covering the gear head and magnet holding the arm.
The 2 torx screws covering the magnet end are off. The 2 Phillips screws are the problem. Specifically 1 of them. One came out but was extremely hard to get moving. The second one will not budge and the head is starting to strip a little bit. I don't want to strip it if I can avoid it. I'm using a ratchet and the correct size Phillips head and even pushing down as hard as I can and turning the ratchet, I can't get it to budge.
I was thinking of using some heat in the form of a hair drier. I don't have a heat gun. I could also use a soldering iron and touch it to the head if it generates enough heat.
I also thought about using JB Weld to weld a small nut onto the top of the screw and then using a socket to turn it out. Leaving the nut on wouldn't be a problem.
So I'm asking for thoughts on how to get this thing out without having to drill it out and I know there are tools designed to get striped or hard to remove screws out but I don't presently have any.
Thanks,
Gary
Thanks,
Gary
