I have one of the small Slime air pumps with a cig plug in device. Can I use the outlet in the trunk if I need to?
The RS trunk outlet is only fused for 3 amps, but the RT trunk outlet has a 10 amp fuse. That should handle your Slime compressor, but check the rating beforehand...or have a spare fuse handy. BTW, the Slime compressors (at least mine) come with alligator clips, so you can just attach those to the jumper terminals under the seat, if need be.
Teddy has one of those lil Slime Pumps & we plugged it into the trunk outlet last year & it worked fine & didn't blow anything :shocked: Guess we got lucky :dontknow:Tested out my Slime mini pump on the trunk outlet and had no issues.
So, here's my dumb question: what's the *point* of the RS frunk outlet if you can't plug anything into the dang thing?
I'm guessing all it's good for is a phone charger, that's it, right?
Not so hot for a phone charger, either, since it is not live when the Spyder isn't running. That's why lots of folks add auxiliary outlets elsewhere.So, here's my dumb question: what's the *point* of the RS frunk outlet if you can't plug anything into the dang thing?
