It is sometimes funny to go back and re-read these threads.
Rule #1....Most of us are older geezers. We have our minds made up. Don't need no steenkeen manuals or advice. Do our best to try to convert everyone on the site to our opinions. No reason to get mad at others. IT IS THE WAY IT IS.
I am on the wrong side with my 87 octane and 10% ethanol. Over a hundred thousand miles on the Spyders since 2014 when I made the change over from premium. Still haven't blown up an engine or had ANY major damage. Right BlueKnight? :yes: I listened to BK and it seems to be working for the both of us. We MUST be right. :roflblack:
You make some very accurate assessments here.
You're not on the wrong side of anything with your 87 octane and ethanol mix. The ECU is designed to compensate for virtually any clean, uncontaminated fuel you are likely to run into. Though it can't compensate for the potential downsides of ethanol.
If not blowing up your engine, or suffering any major damage are your essential parameters. Then there is no question that you're all good. I would add, the same principal applies to which oil you use.
However, the fact remains that having your ECU
compensate does have other, less noticable consequences. It is also true that there are several factors which determine how much of a difference fuel octane and mix will make. So, results are not linear.
Still, whether or not a person perceives them, 'Compensation' always has consequences. I think this is what promoters of Premium, straight gasoline are attempting to convey. It's not about being right or wrong. It's about knowing how the machine functions and the facts surrounding your options.
Is premium fuel Required? No. I don't know if I've ever seen anyone try to make this point.
Is premium fuel ideal? The Rotax engineers that made the motor, along with the stated compression ratio, would seem to make a strong case.
No one should feel put-upon regarding the fuel they choose. Nor should anyone attempt to make someone feel bad about their selection. It's your ride. Do it the way you want and be happy!
