Where does the ZUMO 660 GPS Wiring on a 2014 RTL run?
I have a Garmin Zumo 660 on my 2014 RTL, and want to remove it, to run the wiring for a Garmin XT. So I'm wanting to know where the 660 wiring runs to before I start thinking about running the wires for the XT.
Right side there’s a connector behind the cover it plugs into. Closer towards passenger right leg area. You have to take the covers off to get to it, and run the wires back to the handlebars.
So you pretty much have to remove all Tupperware, back to right the saddlebag? And is there a way to define that wire from other wires?
Runs beside gas tank. There are 2 plug inside, 1 for power, 1 for audio. If you start up by handle bars, can wiggle to find zip ties to start to separate then, pull up thru that area. The sides around handle bar will have to come off
It’s like in front of the right bag but behind the side cover. It’s a two pin power connector black. It’s an involved job especially around the handle bar area. I removed the right headlight to to get to the steering area where it comes down from the handlebars. The audio plug as mentioned will not be used with the XT.
So right side covers do have to come off it a larger black cable. Try not to damage it they are expensive and don’t recommend pilling hard on those cable. They damage easy
