If you want a rough guide to what the 'proper' table from the manufacturer will contain, look for the Max Load xx lbs @ Max Pressure yy psi that your tire will have printed on the sidewall (well, they do/must have that info in Aust anyway!! :shocked: ) It's going to say something like this:
Max Load 1550 lbs at Max pressure 38 psi
That's all OK, but the loaded rear tire of my Spyder usually only weighs in at about 515-520 lbs with me & my 'normal' solo load aboard, so how do I work out what pressures I need for MY Spyder & its normal load?? You hafta do a bit of calculating to scale the Max loads & Pressures down to the loads you are usually putting on your Spyder, & your calculation might be a little different to mine simply because you load your Spyder differently & you may weigh something different to what I weigh! So
MY 'rough calculation' to work out the necessary 'cold start' tire pressure goes something like this:
The Max Load if 1550 lbs divided by my actual load of 515 lbs = 3.009 or by 520 lbs = 2.98; therefore I need to divide the Max Pressure of 38psi by 'about' 3 which comes to about 12.6-12.8 psi for the static load on my rear tire - but you need to add 4 psi to allow for the extra stresses of 'driving' over that of static loads & that gives me a rough guide for the necessary 'cold start' pressure of 16-17psi solo - and when I tracked down the actual table from Kumho it worked out to be pretty damn close to that, specifying 16psi for 520 lbs. I did the same rough calc for the weight of my fully loaded & rider plus pillion carrying rear tire, that calc worked out at 17.5-18psi & the Kumho chart said 18psi to carry 540 lbs.... The front tires (I run 175/60R15 Kumho KH17's) worked out at 16psi solo & pillion (no measurable difference between solo or pillion weights on the weigh bridge I used) & the Kumho chart said 16psi....
So as recommended by the tire manufacturer in their weight/pressure table and by the rough calculation done using the weight/pressure info printed on the sidewall of the tires, I run 16 psi up front in my slightly larger than stock sized Kumho tires for both 1 or 2 up; and 16 psi in the slightly larger than stock sized rear tire solo, 18psi in the rear when running loaded & 2 up. :thumbup:
With the sort of riding I do, I'd expect a 'closer to OE Spec sized' car tire to need slightly higher cold start pressures to carry similar loads; a bit more pressure again to carry greater loads than those I usually carry; and about the same or possibly a touch less pressure to carry lighter loads. Those 'cold start' pressures should be adjusted up or down a little to cater for different ambient &/or road surface temperatures (colder climates might need a couple of psi less to help them get warm enough for proper traction on cold roads; while hotter climes may need a couple of psi more in them to stop them over-heating on hot roads!) & maybe for more or less spirited riding, but they are a pretty good start & the 4psi Rule will let you fine tune them to the optimum for your Spyder tires carrying your Spyder loads.
NB: the recommended pressure for a Kumho KH16 or any other size or brand of tire may well be different to that outlined above, so don't just use the figures & calcs above as verbatim for you/your tires unless EVERYTHING is exactly the same; ie size, tire brand, tire type, loads, where you ride, etc - they are provided here as an example of how to derive them & do the rough calcs & are really only applicable to me/my tires, loads, & circumstances; & my 'guesstimations' of what other tires may need are just that, given the assumptions outlined & some guesses about the expected loads on Spyders; ie, they are guesses & estimations provided to help you grasp the concepts discussed. YMMV.
