what kind of engine would you like ?
A long stroke v-twin would be difficult, given the current architecture. There is precious little room under the frame, above the valve covers, for this shorter stroke version. A taller frame, to accomodate the engine, would cut even further into the fuel tank area. A boxer engine would be easier to work with for several reasons...although a severely canted four or six inline, like the new BMWs, might work.
50 mpg ain't gonna happen with anything the size of a barn door, with the aerodynamics of a parachute. A more aerodynamic vehicle would kill the look...especially with the suspension covered. I don't think we want clones of cages. Some things may be desireable, buit they aren't always practical...or pretty. Nice to dream about, though. Perhaps a hybrid is the answer.
How about something along the lines of the Honda Magna engine? A V-4 would give more head room and the Spyder seems wide enough to accomodate more width. That might allow a significant bump in CC's. And the Magna is no slouch in HP either.
Hadn't thought of that. Ah, the stuff dreams are made of...
Well, I'm no engineer and I suppose there are all kinds of reasons it wouldn't work. But you're right. A dream does not have to be engineered.. At least in the early stages, that is! :ohyea:
it`s told that ROTAX workes on a new engine for the spyders ..
the have different modells on their webside www.rotax.com
so what kind of modell you would prefer ?
for me could be better
fuel-consumption / torque /oil-service intervall /
and a little more HP..
maybe a little more show - like here
I would like to see the 1,800 Honda V Twin Water Cooled. This bike needs lots more low end torque.
Also they need to make it about 4 inches longer, and have regular handle bar brackets so you can put them wherever you want them without having to pay 600 dollars.
Drive Shaft This belt arangement is NOISY
I Definately would say more fuel economy . Maybe have some kind of special models for speed demons and more fuel efficeint models for some of us who cruise ?
If it fits in the water sport toys, let's envision this 215 HP engine in the RT. I know, I know, but we can dream, right? http://www.rotax.com/en/Innovation/
I have been thinking the same thing for a while now. :D
RSV4 from Aprilia (186 HP):
  • Engine capacity: 999.6 cc
  • Architecture: 65° V4
  • Crankcase: monobloc with integrated crankcase liners
  • Timing system: 4 valves per cylinder (Titanium and Nymonic) operated directly by a camshaft driven by a mixed chain/gear system, lateral timing chain, central gear train
  • Fuel system: Electronic injection with 2 injectors per cylinder and integrated independent Ride by Wire system for each bank. Three mappings selectable from handlebar.
  • Antivibration countershaft
  • Compression ratio: 13:1
  • Transmission: 6-speed direct-control cassette type gearbox
  • Clutch: Multiplate wet clutch with mechanical slipper system
  • Electronic management: Magneti Marelli control unit managing ignition, injection and Ride by Wire system, and variable length intake ducts
  • APRC system for dynamic control
:2thumbs: Perhaps this will be Spyder X some day.
