obiwanbill
Just bought a 2020 RT Limited Chrome. Curious what improvements/changes were made to the 2021 and 2022 models of the same bike?
thanksView attachment 194364 photo of actual bike, take delivery on Tuesday when it gets up to 42 deg In Ohio. Today is 5 deg
There are unsubstantiated rumours (albeit from reliable sources), that the later built ‘21 models also had a new front pulley to reduce the whistling that some ‘20 riders report, and also changed front mirror posts to reduce mirror vibration, obiwan, but that’s about it. :2thumbs:
Can trufally say there is know mirror vibration on my 2021 RT.
Might have or perhaps prior owner installed the Lamonster bolts? Didn't vibrate, was clear on 20 min drive home from dealer. Still to cold here in Ohio; expectation up to 14" of snow between now and Friday AM here in OhioDidn't BRP come out with a retrofit kit to eliminate the mirror vibration? Check out that possibility Obi. Maybe your Spyder has already been fixed.
They need to fix the side mirrors so that they do not shake
Checking for a roller is pretty easy, I did itwhile shopping for 20+ RTL new or used. Just run your hand along the top of the belt forward and you will feel the roller its a little bit of a stretch but not bad. Worst part for me was getting up from lowering myself to my knees to reach the belt![]()
