I just purchased a new 2014 RT Limited (Cognac) and have already learned a great deal by reading this forum and everyone's posts. I know this is a subjective question but I was wondering what folks think are the best accessories to start adding on? Seems like everyone likes the sway bar. What accessories should I start with first?
As you can see, most are stating the BajaRon Sway bar - ABSOLUTELY, but make sure you add the Aluminum Links!
Other then that - LASER alignment from someone that really knows what they are doing. Meaning they have done a bunch and those customers are satisfied.
I would also suggest a module to Flash or Strobe your rear brake lights.
After that its really up to you. Lots of stuff. Corbin, Utlimate Seats, Sticky Convex side mirrors, whatever makes you safer AND more comfortable.
The hardest is probably seats. they are expensive and just sitting on them for a minute or two will not give you a sense of what they are really like over the long haul.
However, if you come from the 2 wheel world and liked a particular seat (other then OEM) you will find that the CanAm equivalents are pretty much no different.
DO NOTs!
Do not waste your money on the CanAm CB. Although the same unit as the Harley under performs and lots of problems. If you want or need Comms go with a Bluetooth system.
If using a new Lightning connector iPod, do NOT buy an adapter from any manufacturer other then Apple.
Good Luck & Congrats on your new Spyder.
AJ
