Washable oil filter
rays hell
I just found out today about a washable oil filter. After a little research found that K&P Engineering make one for each of the
Rotax engines. The S81 is for the 1330.
I'm curious if anyone has had any knowledge or experience.
I have had a K & N filter in my 1330 for 2 years now.
Do you have it just to save money (I know you do a few miles) or is there a efficiency benefit as well?
These have just started being sold over here and so I was wondering what the benefits are but there doesn't seem to be much info.
I change my oil filter and oil more often than the schedule just because of the sort of riding I do, so cost wise it makes sense.
I you sure you don't mean "air filter"?
Yes to both questions, just not in a Spyder. The technology has been around for years. They are a very good alternative. They are messy to clean, but they filter well and work as advertised. They're expensive to purchase, but if you plan on keeping your bike for a while they are very cost effective. The easiest and best method for cleaning is with mineral spirits or similar, you don't use gasoline. Rinse, dry, re-install, repeat. :thumbup:
I don't have one but if I try it I would do oil analysis with a regular and then the reusable filter to see the difference at the same mileage. If you can do oil changes at 9,300 on the 1330 I'm not sure of the benefits unless it filters better.
WASHABLE OIL FILTER
I would have serious concerns about this filter meeting - WARRANTY REQUIREMENTS .... I think BRP could easily make a case for denial ...... and I'm a strong believer in Moss-Magnussen ............... jmho .... Mike :thumbup:
Well....
I find for an item of such importance to your rather expensive motor why cut corners. If on the otherhand it does a way better job than a new filter by all means go for it. I will stick with a new filter with every oil change...
:agree:
I ran a K&P (transferred from one to the other at trade in) in my Harley's for years and 1000's of miles with great results. I liked how I was able to see anything that was trapped by the filter. One time I found a very small orange piece in the filter and as I was trying to think of what in the motor would be orange I looked over and there was my orange funnel that I use to fill the bike with oil. It was a small shaving from that funnel.
K&P Engineering
Navigation– Home– Technical Info–– Filter Dimensions–– Filter Housing Finishes–– Primer on Filtration–– Technical Information–– Testing– Applications–– Aircraft–– ATV–– Automotive–– Construction Equipment–– Generators–– Industrial–– Lawn & Garden–– Marine–– Off Road Bikes–– Personal Water Craft–– Road Bikes–– Scooters–– Snowmobile–– Trucks– Product Catalog–– 2100 Series Filters–– S Series Filters–– Heavy Duty Filters–– Filter Parts– Cleaning & Assembly–– Assembly Spirol Lok–– Assembly Twist Lock Style–– Cleaning–– Spirol Lok Disassembly–– Twist Lock Disassembly– Dealer Locations– FAQs– Videos– Brochures– Dealer Resources– Contact
[h=2]Technical Information[/h]
[TD="width: 570, bgcolor: #cccccc"] Technical Highlights
[/TD]
[TD="bgcolor: #cccccc"]
[h=3]The most technically advanced oil filter you can buy[/h]
  • [*=left]Consistent filtering across entire filter surface
    [*=left]Superior ASTMF316 filtration performance
    [*=left]7 times the flow of comparable paper oil filters
    [*=left]Magnetic Prefiltering
    [*=left]Billet aluminum filter case doubles as an oil cooler
    [*=left]Progressive rate bypass combined with high flow characteristics of the filter media avoids unfiltered oil bypassing the filter during cold startup and high rpm
    [*=left]No more cutting apart messy paper filters for trapped debris inspection
    [*=left]Proven in Motorsports, Military and Aerospace applications for years
    [*=left]No more oily paper filters to the landfills
May be the last oil filter you’ll buy
“Inspect, Clean, Reuse”
[/TD]
[TD="bgcolor: #cccccc, colspan: 2"]
Unique Design, Top Quality Materials and ConstructionThe K&P Engineering filter element is made from medical grade, type 304 stainless steel micronic filter cloth to provide unmatched protection against oil contamination and resultant engine damage. A one inch square of this material flows an incredible 1.9 gallons of oil per minute at only 1 PSI pump pressure. The adhesive used in the filter assembly process is good to 600 degrees Fahrenheit, far above normal engine operating temperatures. A super strength nickel-plated neodymium rare earth magnet is installed in the top of the element for magnetic pre-filtering of the oil. The sophisticated bypass is engineered for proper differential pressures and consistent operation, delivering a greater percentage of filtered oil while being very easy to clean. The twist lock design assures positive filter element placement and allows for easy disassembly, inspection and cleaning. The quad-ring gasket doubles the seal between the filter and the engine. Finally, the filter housing is carved out of a solid chunk of 6061T6 billet aluminum, which not only looks trick but aids in dissipating heat.
[/TD]
Questions or Comments: [email protected]Links |Statement of Liability |Site Map
Dealer Ordering and Support: Tel: (720)238-1181 Fax: (303) 697-0404Designed by Denver Website Company Creativewebsiteings.com©
