Campverdefela
I installed these today, not too difficult. First I had a friend make me a thinner backing plate using copper plate, see photo's. Not necessary I just wanted a lower profile. Then took off the rear fender and running light and taped into the wiring harness where the clip holds it to the inside fender frame. Snaked the wires thru and over to each side [see photo's] I used AC-Heating tape that techs use for sealing around pipes and wiring going into duct work. I cut the wiring snug so if the tape fails where I secured it to the fender frame it still wouldn't rub the tire. The led lights run 6.95 ea. You should be able to get the tape at an heating ac supply store.
