And my 2024 Spyder RT Operator's Guide shows Fuse #6 in the right fuse box as "GPS_Acc".
I believe it came with no fuse installed in that location.
Because CAN-AM fumbled around before getting Apple CarPlay to work correctly, I ended up buying a Garmin Zumo XT GPS and mounting it to my handlebars. I wired it into the accessory power port on the right front of my 2024 Spyder RT.
I used this custom plug for the connector port.
Easily power your favorite Can-Am Spyder RT 12v accessories with our Plug and Play power harness
www.lamonstergarage.com
The following picture is part of the Lamonster install information, and shows the original wire hanging down in the lower center with the orange tip. The port it plugs into is in the upper left corner. And of course you can see the suspension of the right front wheel in the lower right.
The Lamonster GPS harness is a "Y" cable that plugs into the port on your Spyder and has a female connector that you plug the original wire into, and uses "wago blocks" to connect the wire that you run from your GPS to that location.
