Ride Master
here is a thread from me and BRP:
Everyone knows that the belt is too loose for being as long as it is. The vibration conversation is all over the "Spyderlovers" forum. BRP lowered the spec because you were having bearing and sprocket problems.
At the higher original spec, there was no vibration.
I Have 2 words: one starts with a B and the other starts with an S.
You should do what is right and increase the spec back to 700 Newtons +/- 150 and let us enjoy our rides while you concentrate on your bearing problems.
Bob Lintz aka "Ride Master"
Laguna Niguel, CA
On Jul 23, 2012, at 1:32 PM, Spyder, TechSupport wrote:
Greetings Mr. Lintz,
All our Spyder vehicles have a vibration around 5400 RPM which is a normal characteristic of the vehicle. If your dealership does not feel that this vibration that you are experiencing with your vehicle is the normal vibration, they should contact our technical assistance line for dealerships to work on diagnosing and resolving the issue. Being a normal characteristic of the vehicle, this harmonic vibration has no need to be fixed.
Have a great day!
2012/7/6 Bob Lintz wrote:
I've had my 2012 RT Limited in 5 times for the vibration.
1st 3 times I was told it was ok. Well it's not ok. I know they reported it to you.
I see complaints from other Spyder RT owners about the same thing
I had my dealer install the SmoothSpyder belt tensioner.
They set the drive belt at minimum tension and the tensioner at 10 pounds...all this did was change the rpm at which the vibration starts from 5200 to 5500 rpm
Then, my dealer adjusted the drive belt to 600, the maximum, and the tensioner to 12 pounds. All this did was change the rpm at which the vibration starts from 5500 to 6000
My dealer refuses to tighten the drive belt further but, we all know that's what is needed. The folks at SmoothSpyder suggest the drive belt be set to 700-800 Newtons but know you are currently not allowing it.
The vibration is serious and is going to damage the RT. I want it fixed and fixed now. Either that or I am going to retain a "Lemon Law" specialist. The drive belt is just too long to be at 450 +/- 150 Newtons
Laguna Niguel, CA
Have a great day!
