groundeffect
Registered User
1. Measure and order from BRP the new shims. TIGHT valves (small clearance) are open longer and the motor breathes better and makes more power but the valves don't last as long. LOOSE valves (lots of clearance) are closed longer, run cooler (due to ability to transfer heat to head), last longer but don't make quite as much power.
2. This is not happening overnight, the clearance is getting tighter and tighter between 2 measurements.
3. Overheating/burned (most likely exhaust) valves may result.
THANKS doc!
I think you may have answered this, but:
A. Does the valve clearance gap usually get looser (say for example a clearnace of FROM .0087 TOWARDS .0114in ) with time and miles?
OR
B. Does the valve clearance gap usually get tigher (say for example a clearance FROM .0114in DOWN TOWARDS .0087 ) with time and miles?
B, correct?
Thanks.
