Wondering if anyone has actually had to have their valves adjusted during a check?
Considering the expense of a valve check, just wondering if anyone has really had them adjusted during a check. I think BRP's specs on checking them so often is a bit overkill.
Ideas?
Ideas?
I don,t think they let you watch:roflblack:???:dontknow:
It would be nice to hear from someone who had their valves adjusted;
Not just billed for it but, Actually seen them do it.opcorn:
Do you really think they go to all the trouble of Lubing the grease nipples at 600 miles:roflblack:???
I,ll bet most techs don,t even go to the trouble of checking the front plug even though your charged for it:roflblack:???
With the help of this group I will do as much as humanly possible myself so I know its done!!!:yikes:
:2thumbs:I don,t think they let you watch:roflblack:???
Of cause not,can't make money that way.
Of cause not ,can't make money that way.
Ideas?
Pretty cynical group we seem to have here. That is most unfortunate. I have to say that I have never doubted that my tech did the work he said he did. Sometimes I wish he had done more, but I have never found evidence that he lied...and I have found lots of evidence that he did his job. I'm positive he lubes the fittings, because he always fails to wipe the excess grease off! :roflblack: I don't know how it is in most states, but here in Michigan the law comes down hard on shops that charge for work they don't do. It is sad that so many of you seem to have been burned. Find a shop you trust. It may come in handy some day, even if you do much of your own work. I suppose you guys do your own warranty work, too, and that the reported "backorders" are really just extended coffee breaks. :joke:I don,t think they let you watch:roflblack:???
Yes, I can do a valve check myself, but it is easily a 2-3 hour job. With shop time, which includes dealer overhead, at $75-$125 an hour these days, that's several hundred dollars any way you cut it, especially when you add the parts that are needed. You have to remove the body panels and the airbox. Even then, getting the valve covers off is tricky, as is getting on the new ones without damaging the gaskets. Adjustment will be much worse. Trust me on this. If you are going to start comparing working on a Spyder to working on your Chevy, you are going to be in trouble. That actually goes for any bike with a full fairing. You don't just pop the hood and take off the wingnut for the aircleaner. If you want Chevrolet ease, buy a naked bike!Yes it is unfortunate. Even more unfortunate is the sad truth that many if not most of us HAVE been taken advantage of by crooked dealers or independent shops. Factor that in with the fact they are charging several hundred dollars to do a valve check. I can do it on my Chevy with relative ease myself. It's just kind of hard to justify. Who did your valve check? I am just curious. It seems to me that you are one of the guys out here that could do the job yourself. And I say that with much respect!
Frankly, I have heard of disreputable mechanics many times, but in 50+ years of being in the thick of automotive and motorcycle ownership and hobbies, I have seen very few. Maybe it is how one looks at people in general. Expect to see the bad, and you probably will. Expect the good, and you may well find it. At any rate, condemning dealers (or automobile drivers) in a wholesale fashion does a lot of good people a real disservice, IMO.
:agree:After reading that Doc had to wait for them to get shims in---- :gaah:
Why on earth would they do a valve check without the shims READY and ON HAND to fix it? :shocked:
1. Measure and order from BRP the new shims. TIGHT valves (small clearance) are open longer and the motor breathes better and makes more power but the valves don't last as long. LOOSE valves (lots of clearance) are closed longer, run cooler (due to ability to transfer heat to head), last longer but don't make quite as much power.My questions are:
1. What happens when the valve clearance goes out of spec?
2. How will we know when they go out of spec... as they could go out of spec before we bring Spyder in for the service of course. What are the ways we, the ryder can tell if they are out of spec?
3. What kind of failures could occur if the valves are unchecked and does in fact need to be adjusted to within spec? Damage?
In addition, as I understand it, the tank has to at least be loosened and moved back (or removed for more space) to access the rear cylinder valve cover for the check or adjustment of the valves.
Thank you. Cheers.
