agedbikeman
Can anyone help, on my 2014 RT standard 1330 there are only 2 switches on the panel under the handlebar, the parking brake and heated grips, but inside the panel are 2 spare connectors, one with 4 wires and one with 7 wires, ready to be connected to switches for optional extras
View attachment 145178View attachment 145179View attachment 145181View attachment 145182View attachment 145183 The connector in pics 1 & 2 with only 4 wires are the ones i'm interested in, does anyone know what this one is for? The red and black wires measure 11.55 volts when the key is on rising to 13.5volts when the engine is running. The 11.55volts remains after key is turned off until display screen goes off, the other 2 measure nothing. This would be convenient to connect to an accessory I'm fitting but I'm worried that it could damage somthing as it only reads 11.55 volts when the battery reads 12.5volts. Is this the connector for the suspension pump on other models or is it the other 7 wire connector. The accessory works when connected briefly to the red and black wires of the 4 pin connector, I only require 1.5 amps maximum.
The wiring diagram I have is so poor it tells me nothing. I suppose I could pull the fuses one at a time to see which circuit it's on but that a lot of work if someone knows the answer.
Thanks for any input.
Alex
Alex
