Tweeters in place of gauges?
taxmyzer
Has any one put tweeters where the gas & temp gauges are? Would like to keep everything stock so I can put the OE gauges back should the need arise.
tweeters
it's a great idea, when i first removed mine i bought 52mm plugs for the holes and than replaced them with a volt meter on the right side and a clock temp on the other
if your adding them to a existing system it may work but then you "should " have a lot of highs and not a lot of midrange . if you can deal with that just make sure your crossing them over at the right frequency
