turn signals
major911
Got home from a ride tonight and noticed that all my turn signal lights were on (front and rear) like running lights. I thought this odd so I decided to test them out. when a turn signal or hazard switch is activated the indicator on the dash flashes rapidly but the actual light just stays on. checked all the bulbs, none burnt out fuses all look good. Checked the relays they are all snug. I'm stumped. usually in a car this indicates a burned out bulb but all seem to be working. Couldn't find anything in the owners manual to help so I am appealing to the SL expert team:popcorn:
lighting mods?
have you done any lighting mods lately ?:popcorn: or any other mods that might have disturbed some wiring ?
Disconnect them one by one to see if you can narrow down the problem to one circuit.
Are all the bulbs stock or did you or anyone else change them to LED's?
Do you have the ESI Double Play or Triple Play mods installed?
THE TURN SIGNALS
I believe He recently put Risers on and said He had difficulty finding enough slack ......could this be connected or dis-connected/ pinched something ?????.....Mike
can use this to see alarm in the spyder
With ignition switch on (or engine running) press MODE button repeatedly until "engine hours" (total hours) shows on display.
Press and hold MODE button while pushing the "flash high beams" button five times within 2 seconds.
If there are no active faults "No Active Fault Code" will be displayed.
If there is an active fault, an alphanumeric code will be displayed. This can be looked up in the shop manual (available on CD) or you can ask on SpyderLovers and someone will look it up for you.
If there is more than one active code, you may press MODE to cycle through them.
I believe this procedure is in your manual.
check fuse box , batteri cable ground cable daze cable , cable to led light on fender
ok I took the LED fender tips out today and replaced them with the original bulbs. When I first turned the key on the turn signals in the rear were off like they should be. I tried the left signal and it worked fine. Tried the right and it stuttered a couple of times then quick blinking and went to constant on. rapid blinking indicator on dash. after a couple more tries now neither side works stays lit all the way around and lights don't flash. I can't think of anything else. retraced wiring harness from the riser install and all wires and plugs are secure with ample slack rechecked battery connections, fuses and relays. all intact. Gonna try that code sequence that someone else mentioned to see if there were any codes thrown.
Tried this procedure and it doesn't work. Looked through the owners manual and there is nothing like this step in there either.
You bought this used, didn't you? Are you absolutely sure there is not a TIPS (front clearance and/or mudflap lights blink with turn signals), Double Play (front turn signals double as running lights), Triple Play (rear brake lights also function as turn signals and rear turns function as brake lights), brake flasher (brakelights blink several times before coming on solid), or LED replacement bulbs installed in turn signals? If everything is stock, the Spyder was not washed to get water in the turn switch, and there are no lighting or wiring mods, you may need the cluster reflashed or need a new one. There is no turn signal flasher on the Spyder, the signals are controlled through the cluster. In troubleshooting, other than looking for accessory modules wired in, I'd remove all turn bulbs and try again, replacing them one at a time. It still sounds like you have a lighting mod, though, that is the only way the turn signals and clearance lights would be connected, so your bulb mod affected the signals. Could be coincidence, but I doubt it.
I did buy it used. I have gone over the spyder with a fine tooth comb. All stock lighting, no wiring unaccounted for. All incandesent bulbs. The only change was the LED fender tip bulbs that I put in a couple of weeks ago. That was the first thing I removed today when I began this troubleshooting mission. now during my riser install I had the dash cluster in and out several times and the first removal was a bit traumatic because I couldn't figure out how it came out. I actually cracked the lens on the front during removal. After that I learned how to do it and didn't have anymore trouble. when all mods were done everything worked fine. I did pre ride inspections and tested all lighting. so I know that this problem just surfaced yesterday and the only thing I did yesterday before riding was to install a new windshield.
ps. I have washed the spyder several times. I do try to be careful with water around the dash and I always use forced air dryer on it afterwards. Not sure if that explains anything...
The cracked cluster lens and washing the Spyder doesn't sound like a good combination. I think it would be best for you to leave this one up to a good dealer...and bring your checkbook.
That leaves me with a rather uneasy feeling...LOL but I appreciate your opinion and candor. I'll seek out a reputable and hopefully charitable dealer Thanks Scotty!
I guess the next thread I need to research is the best way to wash the spyder. Sounds like I'm doing it wrong.:banghead:
moisture
is there any moisture inside your cluster lense ? maybe check to see that the harness is snapped on to it completely.:popcorn:
I pulled the cluster and checked it thoroughly, no moisture. I unplugged and replugged the harness. No change.
LIGHTS PROBLEM
Cracked cluster lens and Water does not sound like a good thing.....JMHO........Mike...............PS good luck
fender tip bulbs
check fender tip bulb sockets and wires going to them. i remember someone recently had a problem with a loose wire in a fender tip socket. those sockets, as i recall, are kind of cheesey.:popcorn:matter of fact, when i put led tip bulbs in mine, the right bulb had trouble maintaining contact.
First thing i did was remove the led bulbs from the fender tips and put the original bulbs back in.
