Is the Reverse light bulb also a 2621A bulb?
RPM
Hello!
I have my 2022 Sea-to-Sky bike at Clearwater Lights installing a Keri/Erica hybrid combo and a Billie brake light. They have taken everything apart (first time for them) and called me as I have an order from slingmod coming tomorrow and I will put in the brake modulator while it's all apart. I'll order a pair of OXILAM 7507 PY21W BAU15S LED Bulbs Amber Yellow 2800LM for Turn Signal Lights with Build-in Load Resistor CANBUS Error Free 2641A lights and want to know if the backup reverse light is also a 2621A bulb. Might as well change that out while everything is apart.
Clearwater Lights are the BEST. I had them on a Victory Cross Roads that I once had. Glenn is extremely helpful there.
Thanks!
I would like to see the differance that the OXILAM 7507 PY21W BAU15S LED Bulbs Amber Yellow 2800LM produce... You should get a pic of one after install, to show the differance.
I will do that. The main reason to switch out the bulbs is the much longer life of LED bulbs. Also, nice to have all LEDs in the back of the bike.
