Turn Signals blinking fast, but 4-ways normal. LED's installed. Any ideas?
I know on my truck if the turn signals start flashing rapidly, then one of the lights is out. Not sure if it is the same on the Spyder, but it couldn't hurt to check. Or I could just be an idiot.
I had this exact same problem when I had a 2012 RTS. Left side would flash rapidly and right side would flash normal. Check to make sure all your lights are working. What I found on mine was that the connector to the turn flasher on the front of my left side view mirror had come disconnected. Removed mirror and refastened connector and all was good. Hope this helps.
Fast Flasher Fix for 2011 RT
I think the 2014 was the first year the turn signal flash speed was reprogrammable.
Where can I find appropriate "resistors" if I want to add spuderpops mirror turn signals?
A Noob
This should work to reset your turn signal speed
1. Turn key ON
2. PRESS & HOLD Hazard Button for 30 sec.
3. Cluster will flash once( I never saw this happen)
Reset Complete
Cruzr Joe
Resistor Directions
2011 RT... about to add spyderpops mirror turn signals and need directions once I experience the fast flashing--any sources out there?
A Noob
Do you have any added lights hooked to the turn signals?
If not then double check all bulbs are working. You could have a couple out in the tail lights that might not look like it unless you inspect closely.
If you have any add-on lights you may need a resistor.
Bob
