Schultzi
Registered User
I don't see the wire that goes to these in your picture.
Where does the wire go/come to the lights?
Was the price $9.00 per light?
Thanks
the wire come out off the triangular tip on the light, i mounted the light close to the edge off the mirror so you dont see the wire.(if you look really close you be able to see the wire)
As stated in another post, i drilled a little whole on the inside of the mirror housing and run the wire through and spliced in to the org. wiring at the mirror.
And yes the price was around $9.00 for a pair of these.
(come as a set of 2)
Hope that helps
