I added V strip LED lights to the mirrors and wired them into the blinker lights. They are for sale on ebay for around $20. They have a adhesive backing. I like the way they look and can be easily seen in traffic.[/
Any chance of providing details with respect to wiring of these LED Chevrons?
Were you able to run the wires behind the mirrors and through the mirror housing without dismantling the mirror housing?
This is definitely a mod I am looking to do so any help would be greatly appreciated.
Did you check the contrast settings for the new cluster in your setup menus?
I plan on trying LED's. Low power usage with brighter results. The next time I have the dash all apart I plan to take a look at this.
Word of caution. I have not looked into this, and have no idea if this will void my warranty or not so I will be checking around first.
That said, our new 2011 Cluster... is half the brightness of the 2010. So in all angles of the sun during the day I cannot tell if my blinkers are on or not. Very frustrating....... nojoke
Yes. It was set @ 100% and I brought it all the way to 40% with no change at all to the blinkers in the dash.
I understand that. My error. The way the previous post was worded, it sounded like the display itself was dimmer. Not sure why changing clusters would affect indicator brightness. That is odd.The contrast setting does not effect the turn signal indicator.
Assuming that I'm actually able to get something to stick to the mirror housing and I now have a couple of wires running from each mirror... how do I get in behind the dash to hook them up??? :shocked:
Why do you want to hook them up behind the dash, Bob, when on the front side of the mirror is the indicator? Wouldn't that be the best option, to break into the indicator wiring there?
Now I'm wondering if I've missed something in suggesting so simple a solution. Is there a snag in doing that? I can tell you that's what I had in mind for a similar mod on my RT. :doorag::hun:
Thats what i installed, wired to the org. wires in the mirror housing
Works great and is noticable even in bright sunlight
$9.00 Autozone
