The fans were NOT running when I shutdown and the temperature is at mid gauge where it always has been once the engine is at running temperature. Thanks for the tip.
Are the fans running when you stop? If so, you might try letting it idle for 30 seconds before you shut it off to take some of the heat out of it before you shut it down. Idling will cool a hot engine down quite a bit.
