I don't believe that you can 'turn the compressor off on the dashboard' at all... You can adjust the 'height' up or down a little via the 'Hard/Soft' switch on the dash maybe (but then as soon as you start riding again, the automatic height setting part of the ACS will re-set the pressure to maintain the height setting loaded by BUDS, so doing that's pretty pointless at the best of times, and it won't stop the compressor anyway!
) You certainly can't turn the compressor off via anything on the dash on my 2013 RT Ltd, nor could you on any of the 2014 Oz spec Spyders with ACS that I've seen/worked on either, and there's been quite a few of them over the years.
You
could try unplugging the compressor,
IF you can get in there to do that, but you might then end up with suspension faults that restrict your ability to ride the Spyder,
OR, if you're game, you might simply try adding saayyy, 20 mls or so of a 'Slime' type liquid puncture sealant to the air bag via the Schraeder valve inlet under the seat (with the valve insert removed to add the Slime, then put it back in again before adding air.
) and add about 20 psi of air to the bag before going for a little bit of a ride to let the Slime seal any punctures /leaks that might be present. That 'Slime' thing has worked pretty well as a temporary air bag repair for me and for quite a few others that I'm aware of too, but it's not necessarily a 100% sure fire fix, nor is it necessarily permanent - altho if it does work for you, then you might as well just ride with it like that until it doesn't work any more... I know of a few Spyders that have now run something over 100,000 miles with a 'Slime Sealed Air bag' without any further ACS issues, so you might be lucky.
Good Luck!
