gottago
Was doing my year end oil change and winter prep today. Well things didn't quite go as planned. Got the oil drained ok no problem. got upper (short) filter out, was doing one at a time so as not to mix up different size bolts. While putting bolts back in with new filter 1st one (upper) went in fine, 2nd one (lower) was turning kind of easy so I kept turning till it tightened up a little, set my torque wrench at 50 inch lbs ( was gonna do it in stages- 50, 70, 97inch lbs) sounds good right? Well got 1st one to set and darned if the bolt on the 2nd one( lower) broke off. On my way to the dealer to have him (maybe) easy out the broken piece and finish the oil change. Question- Has anyone had this happen to them while tightening up the bolt for filter cover, 50 In lbs doesn't seem like it should snap a bolt off... just wondering any advice is of course greatly appreciated.:banghead:
