Trailering a Spyder RT
I have a 7 x 14 Haulmark that we haul our Spyder with. In fact I hauled it to the Yuma ride in with it. I added a 10" by full width ramp to aid in the transition from ground to door/ramp and that makes it so I don't have jump the edge. I attached it using 3 large hinges so it folds against the trailer back door. It climbs the door/ramp just fine and does not scrape going over the edge. I have marine grade eye bolts #8 thru the lower front shock mounts and the tie down hooks go thru those in the front. I wrap a tie down around the trailer hitch on the Spyder and pull that to keep the tension on the front. Stays solid and does not move.
I have a 5 1/2 X 10 foot aluminum trailer from Tractor Supply that I have toted my Spdyer on for thousands of miles with no issues. I just merely drop the standard endgate and drive my Spyder on to my wheel chocks, strap it down, close the gate and off we go.
BIG F
We've made a single sheet of plywood version of one of these that folds onto the stock ramp for travel.
Sounds kinda like Pegasus did, though we made it a 2ft extension full width of the stock ramp, used the
remainder of the sheet to double up at the hinge line to support the ramp all the way wide.
