pegasus1300
Well-known member
I have a 7 x 14 Haulmark that we haul our Spyder with. In fact I hauled it to the Yuma ride in with it. I added a 10" by full width ramp to aid in the transition from ground to door/ramp and that makes it so I don't have jump the edge. I attached it using 3 large hinges so it folds against the trailer back door. It climbs the door/ramp just fine and does not scrape going over the edge. I have marine grade eye bolts #8 thru the lower front shock mounts and the tie down hooks go thru those in the front. I wrap a tie down around the trailer hitch on the Spyder and pull that to keep the tension on the front. Stays solid and does not move.
