Well, i usually dont post things like this, but some of you may have trailers & use them for all kinds of stuff, especially if the wifey comes along on the trips & needs a blow dryer or someone needs to charge a phone/tablet etc :roflblack:
19.5x6 ft enclosed business/toy trailer aluminum pop can...
He uses this trailer for dirt bikes, sled's etc & his roofing bus occasionally if he is really swamped.
Project:
Install heat & Power
Mr. Heater 30K BTU heater, its completely over kill & basically on low with out opening the pass thru doors, you will become a baked potato.
Im still waiting on a vent, he isnt sure he wants a powered vent installed in the ceiling, but i informed him regardless, it needs some venting, as he will have the doors closed when he is sleding out in CO etc.
So here are some pics, some of them are from test fitting stage, some are from a point of almost finished, that is until he seen the poor performance the cheap Chinese light bars he bought for me to add, they have been removed & reinstalled under his addon shelf & cabinets.
He ordered a light bar, well that went out the window as he doesnt like how it lights up the trailer.
He has now ordered some led light strips, which is what i suggested to begin with & place a strip on every 3rd roof beam, so now im waiting on them to get delivered.
As this is a v-nose trailer, he originally wanted the propane tank installed inside with him lmao, that was an instant no from me, the tank is installed on the V driver side & is equiped with a Mr. Heater quick disconnect, the 20lb tank has been used for aout 4 days, roughly 20 hrs & its still going, it hasnt been to cold here tho, but i only use it on the low setting.
The generator has your standard 30 amp 220 port, as he wanted the lights to run on a 15amp breaker & whatever he may power up with a 20 amp breaker, some power tools, an air compressor, & a small lift he has for sled track work etc...
His very own converted pop can aka rolling garage.
Before i get yelled at, yes i did use a load panel, why, because he didnt want a big breaker box, so 220 single phase, dropped to 110 per leg.
As this isnt a true grounded system, GFI's are installed to give him the most protections i could, i told him to install some grounding rod's in his most used locations, but he declined as he goes all over the place.
Grounding bar added to panel.
100w power inverter for the LED's
Cabinet under lighting on its own switch (custom fitted into home switch cover)
USB ports
The 30 amp external wall plug is shielded with a standard 4' box
Be aware this style Mr. Heater doesnt have a build in regulator, so you would need one.
So please make note, when im not doing IT crap, im doing other things :helpsmilie:
Project:
USB ports
