OverHillAndDale
Any suggestions on cubic foot sizes or features?
Features - It should be able to hold stuff:roflblack:. Beyond that:
- LED lighting - not a requirement, but draws substantially less current than incandescent lights.
- A good seal - If you're buying use, run a hose over the top and make sure it's not letting in water. Also, does the rubber seal look like you could change it out?
- Torsion suspension - also not a firm requirement, but will allow the trailer to sit lower than a solid axle under the trailer.
- Convenience - can you reach inside all the areas of the trailer? You don't want things to be able to roll to places you can reach.
- Cooler tray? Nice to have.
- Cubic feet - not a good measurement since the shape is as important as the size. Bring your empty suitcases and cooler, see if they fit comfortably.
