Mine is set to go off 2 PSI low or 4 PSI high. It's adjustable on the FOBO2.
If you're not getting at least a 3-4psi increase from the cold start pressures in your tires after riding for 30 mins or so, then your cold start pressures are too high and amongst other things, while it might 'feel' as tho you have 'more direct steering', due to things like the less traction, more understeer, and increased tendency of the tire to 'bounce' off/over irregularities in the surface caused by that over-inflation, you won't actually be steering/pointing your machine as well as you could be; plus, you'll be wearing those tires more than necessary (probably quite rapidly in the centre of the tread on the rear :sour: ), and you'll be risking punctures/blowouts from road debris..... and there's more too, but you get my drift, I'm sure.
Just sayin' :thumbup:
