Toy Hauler
THE BOLTS THING
The front is 20" wider than the back. 6 bolts - I must check into this. Thanks!
edit - 6 bolts might not be so doable at a campsite, but thanks anyway.
Actually there are 8 bolts but I use 6......The frunk is really supported by two very large sturdy HOOKS that protrude from the frame at the top edge of the frunk....there are four bolts across the top....I only use two because they are the ones that are easily accessible, the other two aren't.....The two under the frunk edge can be accessed if your Spyder is driven up onto doubled 2 X 4's , once you know where they are you can find them by feel....The other two bolts are on the Frunk wings at the ends , you pop off the side panels to expose them....takes about 15 minutes...........Mike :bbq:
I have the identical 26 RR model and can load my RT-S either forward or backward. I just used the existing hold downs and tied though the wheels.
Thank you - Thank you - Thank You. A picture is worth a thousand tape readings. Because of Levodopa, I'll be able to take the little bikes (Vstrom-FZ07) for a couple of years (I hope) but that won't last forever, and I'll go back to needing the Spyder. Again, Thanks for the picture. Chuck
Fine, I'll bite, Bob...
Tango and Cash?
DING!! :yes::yes:
We have a PAIR of winners here!!! :bowdown::bowdown::bowdown::bowdown::clap::clap::clap:
