qasamm
I just finished installing my SpyderPops "missing stuff" and wanted to give a heads up on a few tools you'll need beyond the standard stuff. The Air Management System requires a rivet gun and something to cut a square out of the bottom plate (plastic). I used a cheap $10 rivet gun from Home Depot and made the hole with a Dremel cutting wheel. I am sure you can make the cut another way but be aware of the need.
All things considered the install went pretty good. I am a bit nervous about the belt guard- wondering if it could warp, break or vibrate its way into the belts path causing a problem. It seems secure but...
I also added a Triple Play, wiring to power my iPhone and changed to a high flow filter while I had the Spyder stripped down. I didn't get to setting up my JuiceBox or putting my anti-vibration bars back- I need to cut a few inches off the insert rods because of the new Easy Riders.
Not enough time!
Not enough time!
