johnnyrocket
Now to the serious stuff. Our next installment of Tool Time with Jim.
The next tool on our list is the torch. Now this can be an oxyacetyline rig, a MAPP hand torch, a small "pencile torch or just a plain butane torch. So Let's start with the big one shall we?
Oxyacetylene torches are made up of two bottles of compressed gases. They come in various sizes. The larger set of bottles being about 60 inches tall. These cause the most pain and damage when they fall over when trying to move them around the shop on a cart with less than perfectly round wheels. These torches are normally used for cutting metal which results in hot sparks shooting up your shirt sleeves and "slag" dropping in your shoe causing severe bruising as you dance around the shop on one foot trying to get your shoe off. It is reported these have also been used to heat frozen engine blocks resulting in holes inadvertantly burned into said block.They will transfer heat to your hand from a piece of hot steel very efficiently. They've even been known to burn through leather and "jersey" gloves. These "rigs" can also be MAPP-Oxy torches as well. MAPP Oxy torches produce a higher heat thus causing more pain and suffering at a faster rate.
MAPP torch- This is generally a small hand held torch with a bottle of MAPP gas attached. These have almost taken the place of the old propane or butane torch. Now for you curious types MAPP stands for Methylacetylene-Propadien Propane. In other words it's a stabilized propadien gas. MAPP however is misleading since MAPP gas production ended in North America in 2008. MAPP sold now now is a stabilized LP gas. These torches are used for small jobs such as heating bolts/nuts, braizing small pieces of metal, burning holes in rubber hoses, melting the grease out of bearings that are on the other end of the shaft (note that the aforementioned Oxyacetylene torch will do this more proficiently). This torch will also ignite wood beams, joists and wall studs. It will melt (literally) frozen PVC water pipes too. It will also melt holes in the aluminum walls on garden sheds when put on the floor and forgotten. These torches RAPIDLY heat up your hand and fingers when mistakenly picked up by the flame tip. For times sake, the older propane and butane torches offer the same effects.
The last torch we'll talk about is the Pencile Torch- This insidious little fire maker is mainly used in small electrical work such as melting the circuit board on your welder while trying to replace the linear IC's that were blown when somehow there was a spike in power. These have been know to burn holes in shirt pockets as well.
Due to time constraints and the fact that I have to do more research for tomorrows edition, I will stop here.
Bruiser, you are entirly too funny and you're making my sides hurt from laughing. Can't wait for the next tool time:roflblack:
