On my spyder my thumb is right next to the kill switch. So, for me, the key would take a split second longer.
OK... Just my $.02...
We use the kill switch. I try to go to neutral as much as possible before hand as well.
Now that said... My brain is twisting here...
I would MUCH rather have the kill switch go bad or wear out than the ignition switch.
Please correct me if I am not fully informing this correctly...
We had the rear Frunk lock fall in our hands the first time we locked it. Long story short... BRP told our dealer that we had to replace both keys, tumblers and main switch. As they do not sell just the tumblers. So we got new keys and such. Something about programing issues and such.
And if I remember correctly the main switch is about $300 plus keys and programing of these keys. Oh and a new tumbler for the rear frunk and potentially the Trailer (As they give us a new one for it as well when new).
Aaaaaaanyway. I see the kill switch as a cheaper option parts wise than the main switch :thumbup:. I am sure the labor would be potentially cheaper as well... :spyder2::doorag:
Your assumption is that by using the kill switch you're NOT having to use the ignition switch. Obviously, you'll still use the ignition switch every time, regardless if you use the kill switch or not. By using the kill switch, you have introduced another potential point of failure into the equation, and one I believe is not necessary.
I see no savings here.
:thumbup::thumbup::agree: Yep - Same here - every time.I always use the kill switch. Just in case there is ever a problem while riding, and you need to hit the kill switch, it will be ingrained into you brain. I have an SM5.
...Well, this is about as emotional and divided as the questions about oil, seats, and octane. I'll be glad to muddy things further with my two cents.
I use the kill switch. There is a reason they were federally mandated on bikes. If you use it to shut the bike down, that becomes natural, and you will automatically do it if needed someday. I have always done the same with race bikes, for the same reason. Why not the key? How much control do you have when your hand reaches for the center of the handlebars? The idea is to keep your hands where they belong, doing what they need to do in a critical situation. Shutting off in the garage is not critical, but if the situation were serious someday, you would not want the delay of thinking what to do...or the possible loss of control because you did what came naturally from everyday use, and removed your hands from the bars. I never heard of an MSF course that did not advocate the use of the "kill switch". BRP is new to this game, their manual is not the Bible.
There, that should be worth at least two cents.![]()
MSF course teaches kill switch, then key.
john
