Thank you, Sir.We carry both the Kenda Kanine and the Vredestein for front tires. They are not hard to find. But don't tell them what you are going to mount them to.
You should have no problem on a 2020+ RTWill 165/60/15’s fit in place of 165/55/15 without any rub issues?
Just check the under fender wiring. Especially if you've had aftermarket lighting installed. Make sure the wire retaining clips are not bent out too far and the wires are snug to the fender and not hanging out. Otherwise, you should be good to go.Will 165/60/15’s fit in place of 165/55/15 without any rub issues?
A Vredestein 165/60R15 fit without issues on my F3S. Not so on my 2022 RT S2S. After both shimming the fenders and going to lower profile screws, I still get light rubbing from the Vredestein. None what so ever on either the Kenda Kanine or Achilles 165/55R15 car tire. At some point I may try the new kenda tires for the 2025 RT/F3 Spyders, but not there yet.Will 165/60/15’s fit in place of 165/55/15 without any rub issues?
I just installed Vredestein 165/60R15's, they fit without issues on my 2022 Spyder RTLWill 165/60/15’s fit in place of 165/55/15 without any rub issues?
I just had America's Tire install new Vredestein 165/60R15 tires without issues on my 2022 RTL. I removed the front tires/wheels and delivered them & the new tires. After they were done, they asked what they went on because the 3-lug pattern puzzled them. Only problem was that they were too small to fit on their balancer - So I had them put 4 oz of balancing beads in the tires. (They had to break open a 12 oz bag & divide it into 3 parts). I’ve had great experience with the balancing beads on my truck & cars. Cost me $52.00.In Sept. of last year I ordered online a pair of Vredestein Quatrac 165/60 R15 from Tire Rack and, with prior arrangement, had them shipped to the dealership where I purchased the roadster in 2014. When the tires arrived at the dealership, they called me and I took a morning to ride there and had them installed. Nowhere in my ordering did anyone ask me what kind of vehicle I was purchasing them for.
Same lug pattern & wheel size on the Smart Car. We are still trying to get the torque pattern for 3 lugs!I just had America's Tire install new Vredestein 165/60R15 tires without issues on my 2022 RTL. I removed the front tires/wheels and delivered them & the new tires. After they were done, they asked what they went on because the 3-lug pattern puzzled them. Only problem was that they were too small to fit on their balancer - So I had them put 4 oz of balancing beads in the tires. (They had to break open a 12 oz bag & divide it into 3 parts). I’ve had great experience with the balancing beads on my truck & cars. Cost me $52.00.
Just start at the top and then move to the right and then crisscross to the... Nope, start at the bottom left and then... Ah #$^@$%!Same lug pattern & wheel size on the Smart Car. We are still trying to get the torque pattern for 3 lugs!
Geeez ... I really wonder if the slightly lower profile would work on my 2022 RT S2S fender? Despite shimming the fender and using lower profile screws, I still got light rubbing with past Vredestein 165/60R15's. And it wasn't brake pad noiseWe use Yokohama 175/55R15 on the fronts and can confirm it fits all 4 fender types.
Yes, they will fit the fenders on your S2S just fine. Have installed several sets on current generation RT.Geeez ... I really wonder if the slightly lower profile would work on my 2022 RT S2S fender? Despite shimming the fender and using lower profile screws, I still got light rubbing with past Vredestein 165/60R15's. And it wasn't brake pad noise![]()
