Tire pressure recommendations
TonyMac
Hey all
I searched first to see if there was a consensus on tire pressure recommendations but it didn't seem conclusive.
I've already jacked up the front and rear pre-load springs to max settings and would assume tire pressure is the next setting to mess with.
Any suggestions would be appreciated. Thanks, Tony
I've gone with the 20 / 30 that others have mentioned on the forums. I like the handling better and I haven't noticed and tire wear problems with the increased pressures.
:agree: Changed to 20/30 about the third day we had the Spyder. made it so good we never did bump up the spring settings.
-Scotty
20 front /30 rear, before last notch front/rear. Works OK for 9,000 miles.
I installed Kisan Tire monitors in Nancy's Spyder. Running the tires at . Front 20 psi and 30 psi rear. There is a 80 de differance in tire temps. 80 De lower at an outside temp of 90 de . Than running tire preasure at factory suggested preasures. Plus a lot less tire roll over the beads.
DragonSpyder,
If you look at pg. 79 of your owners manual you will find cold tire pressure recomendations for the Spyder. They are 15 psi. + or - 2 for the front and 28 psi. + or - 2 for the rear.
sabunim5
