bluestratos
I installed my power commander V with autotune a few weeks back and all was working fine. Last Wednesday it started fine and as I was cruising at 25 in town the engine light came on. When I checked there were two codes: front and rear cylinders too lean. Now I have Air fuel ratio Gauge on the bike and a second one for the Auto Tune which agree with each other so I can see that I am not running too lean. No matter what it will not go away. So first question, can I clear the code?
The average A/F ratio at most speeds is 13.2 or less which should be fine if not a bit rich. But the map that they have stored for the Can Am is strange with target values of 13.2 at 60% throttle or higher, nothing below until 7750 RPM at which point they are across the board except for zero % throttle which always 0 which I understand is normal.
Now, has anyone else installed the setup and what were you experiences. If yours is working can you share your map, I have free flowing exhaust and air filter.
