RTS 2012 with an ABS error/pressure sensor - anyone have any idea on how to check if the electronics are faulty?
schmoom
Hello, I have the following problem: I had a problem with the ABS module (VSS module) of a Spyder RT5 built in 2012. An ABS error was reported and the pressure sensor permanently showed a value of >28,000. I have replaced the mechanics with the sensor, but unfortunately I cannot currently get an affordable complete module or the electronics. When I now calibrate the sensor, it tells me that it has been calibrated, but the value remains at this high value. A few seconds later, another ABS error is reported. (Brake values not plausible). Unfortunately, I don't have the B.U.D.S system, but the OBDStar iScan for CanAm (BPM), which has worked perfectly so far. Does anyone have any idea how I can check whether the electronics are really faulty? - All fuses, BLS, brake fluid, etc are ok.
