I purchased my RT in May, annd I love the machine. I don't post very much, but I've read nearly all the posts, and I've learned a lot. Thankyou to all who have posted before me.
I've been reading about the concerns some have about boiling gasoline on their roadsters. So, I started Googling, and using my old college chemistry books. I am not a chemist; I am not an engineer; I am just a retired guy with a run-of-the-mill education. But this is what I learned:
Gasoline is a mixture of many compounds. Therefore the report of a boiling point is given as a range, not a precise number. Water boils precisely at 212 f at sea level. Gasoline boils at about 350 f. The range is actually about 325 f to 375 f. The ignition point for gasoline is about 495 f.
The roadsters Rotax engine runs at about 185 f to 200 f.
So, if you were to open the gas cap, at say a gas station, and the gas really was boiling, you couldn't stick your finger in the tank without getting a serious burn. I've stuck my finger in the tank lots of times because I don't trust the gas gauge. I've never gotten burned or experienced anything hot.
I serously doubt if the smell of gas that some experience is due to the gas actually boiling. Claiming that gas is boiling may be the reason some service tecnicians don't take the claim seriously.
Rather, I think (and remember, I am not an engineer) that the smell of gas is due to fumes from the evap canister, or from malfunctioning purge valves, or from defective hoses.
Odors from evap canisters can be caused by overfilling the tank, hitting big bumps causing gas to splash into the canister, or what-have-you. It can take two or three weeks for the odor of gas from an evap canister to dissipate.
So, if you have this issue, and it lasts for a long time, get the purge valve checked, get the hoses checked.
But most importantly, don't top off the gas when filling up.
Again, I am not a chemist; I am not an engineer; I am not a mechanic. I am just a retired guy who uses Google.
Dan
