Resurrecting my 65 Shelby Cobra roadster ..
You might try using a frame with window screen rather than plexiglass.
I gave that some consideration ……. the problem is finding a Frame that matches the body contour ….. I could make one from 3/4 plywood , but a " window screen ", I want this to be waterproof and sturdy enough to handle highway ( + ) speeds …… Mike :ohyea:
Yes even the lower HP is quite potent.... mine ( from a 93 Mustang ) has the OEM Fuel Inj. If I was to go with a 331 the better option would be a 347 ……. The newest version that FFR is promoting is the all alum. " coyote " eng. w/ all alumin. trans … 400+ HP from a stock 5 lit. WOW …. that combo saves about 150-175 lbs …… very nice in a 2000lb car ……. I also have ( still in the box ) a " new style " F.A.S.T. " fuel inj. system that looks like a carb set-up...… this company was the first to have this ….. now Holley, Fitech, Edelbrock, Edelbrock. even Summit racing makes them ……. Mike :ohyea:
Yep, you are correct, with the lighter weight, even a stock 225 hp roller engine from a fox body will be great. I only mentioned a 331 over a 347 due to some of the 347 kits using oil in the early days. I am sure they have gotten better, but I have been out of the game for a while.
And yes, the new 302 coyote engines are quite potent. I just got back into those last week. I plan on this one being a keeper (just like my lightning). Mods seem to be more expensive. In order to add a cold air kit and exhaust, you are needing a tune, and that puts you at the $2k mark. I am going to just wait a couple of years and then go with a blower and get that 700+ rwhp mark.
