Here is the conversion chart that I send out with the Krikit belt tension gauge. I have found this to be very accurate.
If you would like a copy of this chart. Email me at
[email protected] and I will email you a copy.
It is true that taking tension with the wheel on the ground is not as accurate as lifting the Spyder and letting the rear wheel hang on the suspension. But in practice, it is more than accurate enough. My recommendation is to set tension between the middle spec and the high spec.
Gates Krikit II Conversion Table - Can-Am Spyder Drive Belt Tension (As of 06/15 BRP Specs.)
Tension Conversion from BRP Newton's to Pound Force
Gates Krikit II gauge must be in the middle of the belt (Left/Right) and equal distance from the Front Pulley and Rear Pulley (centered length wise). The Krikit II must be placed on top of the upper belt.
Use Steady, Even Pressure as you press STRAIGHT DOWN on the Krikit II Gauge. Release pressure as soon as the Krikit II Clicks. Reset Krickit II Gauge before each reading.
Repeat process until you get the same reading 3 times in a row.
Done properly the Krikit II is very accurate and more than accurate enough for this drive belt.
[TABLE="width: 619"]
[TR]
[TD]998cc All Models (2008 - 2012)[/TD]
[TD]Min[/TD]
[TD]Spec[/TD]
[TD]Max[/TD]
[/TR]
[TR]
[TD]Newtons - Wheel Elevated[/TD]
[TD]300n[/TD]
[TD]450n[/TD]
[TD]600n[/TD]
[/TR]
[TR]
[TD]Pound Force - Wheel Elevated - Krikit II[/TD]
[TD]67 lbs.[/TD]
[TD]101 lbs.[/TD]
[TD]135 lbs.[/TD]
[/TR]
[TR]
[TD]Pound Force - Wheel on the Ground - Krikit II[/TD]
[TD]130 lbs.[/TD]
[TD]160 lbs.[/TD]
[TD]190 lbs.[/TD]
[/TR]
[/TABLE]
[TR]
[TD]998cc All Models (2013-2015)[/TD]
[TD]Min[/TD]
[TD]Spec[/TD]
[TD]Max[/TD]
[/TR]
[TR]
[TD]900n[/TD]
[TD]1050n[/TD]
[TD]1200n[/TD]
[/TR]
[TR]
[TD]202 lbs.[/TD]
[TD]236 lbs.[/TD]
[TD]270 lbs.[/TD]
[/TR]
[/TABLE]
[TR]
[TD]1330cc All Models (2014-2015)[/TD]
[TD]Min[/TD]
[TD]Spec[/TD]
[TD]Max[/TD]
[/TR]
[TR]
[TD]900n[/TD]
[TD]1050n[/TD]
[TD]1200n[/TD]
[/TR]
[TR]
[TD]202 lbs.[/TD]
[TD]236 lbs.[/TD]
[TD]270 lbs.[/TD]
[/TR]
[/TABLE][/QU
The setting for the F3 seems to work best on my 2017 F3-S. (200lbs., wheel off the ground)
