Not sure how it's set up, but would think if it's close when installed it would center itself?
Like I said, I'm not sure how it's attached.
instructions mentioned how (I thought) but if you set the bar in place and lock down the stays on each end at the same distance you should be centered. View attachment 76773 the round clamp ons at each side of the mounts...good luck..:thumbup:
Yeah, I spent some time thinking on that one too. Since I did not have any means to lift the Spyder, removing it and marking the center and then re-installing it was not something I wanted to do. So, I got the measuring tape out and tried to find some kind of reference point on each end of the bar so that I could center it. The problem with that was, there was nothing I could use as a reference point. So, I centered it as best as I could "by feel". Using my hands to hold the bar at each bend, I was able to move the bar left and right until I felt it was centered. Seems to work, the Heim joint bolts are not hitting anything. Hey Ron, here's another reminder, put a center mark on your bar!
Otherwise I am completely and totally happy with it!
Why is your bar red?
Red was a performance option that I no longer offer. They make your Spyder go faster!![]()
:roflblack: Ok off to the garage I go to finish my install I will report back once I am done and test ride
All you need is a rubber mallet and tap till both links look the same. By the way Ron looked today and after our last conversation and tightening the bushings and it has not moved a fraction of an inch since then nor made any sounds.:thumbup:The reference points are the Heim Joint Links attached to the ends of the bar, not the bar itself.
Maybe 'Centered' or 'Centering' is not the best terminology. Just not sure what to replace it with.
