Hi Bob,
Re: You could "get away" with the OEM links, when using a "Ron-Bar" on the 2010 to 2012 models.
I am sure that your intentions are good. However, you are far from being an engineer. And, IMO, this is dangerous advice.
As BajaRon posted in another thread: There is a lot of misunderstanding and even maybe some bad information out there regarding this whole sway bar issue.
Getting away' with something & running off of the road at speed are two very different things.
Let's leave the technical discussion to the technical people.
Jerry
If you purchase the bar for a pre 2013 RT or for an F3 you do not have to purchase the upgraded links. If you are buying a bar for a 13 or newer RT, Ron only sells them as a set with the links. So even though Bob is not an engineer, what he said was correct.
