delkhouri
I have a 2016 F3-T that I bought earlier this year. I have put a few hundred miles on it and started getting really comfortable with it. A few weeks ago, I had the pulley recall completed and then I bought and installed a sway bar and end links. This was an upgrade I had on my Ryker and I loved it. It was a pain to install because of the needed 24" in height but I was able to get it done. I rode it a few times after the recall and sway bar, and I put between 50-75 miles on it with no issues.
This past weekend I had an outing planned with friends to a cabin about three hours away. So I decided to ride and I got all of two miles from home and the traction control light came on, followed by the engine light and a beeping noise, and then Limp Home Mode Warning. So I turned around and went home. Got in my car and went on the trip. I got home today and started it up, and the warning lights were all still there. I checked the codes and they were C0063 and C006C, which are VSS and Yaw Warnings.
Here are a few things I have read in my search and checked:
My questions:
Other than clearing the Codes myself and riding it to see what happens, I am not sure what else I could or should do, except to contact the dealer.
Any other suggestions?
- the Battery is older but was load tested about a month ago. It showed 13.5 amps at rest and 14.5 when the bike is started;
- the Brake fluid is just under the max line, but the brakes have been a little squeaky lately;
- the Oil is newer and at the right level;
- the Coolant is at right level; and
- I have plenty of experience on a Ryker and know not to rest my foot on the brake.
My questions:
- I have read that the sway bar should have no impact on alignment but could it have possibly triggered the codes?
- Maybe the dealer messed something up with the pulley, but if I need to take it to a dealer to get checked out, it will be the same dealer.
- Because I had some luggage on the Spyder, I took the rear seat off and inflated the air suspension a little bit. I didn't add too much, but I thought it would help with the luggage and longer ride. This was the first time I had ever put air in it, so maybe that triggered something?
