PMK
Here's some pics.
View attachment 145308 View attachment 145307
If I get the whole thing repainted I may match it to my Spyder. But they could probably just paint the top and left side and fix the vinyl. I'll see what the comparative costs are.
Sad to see those scrapes.
After hearing about what happened, I did a quick google search and you are certainly not the first nor last to flip a Bushtec trailer.
Since you do not need the lean function of the hitch, maybe it could be safer to keep the heim joint, but keep it from rotating and only use the misalignment capability of the joint.
As for paint, Pitbull can tell you or send you the BRP color codes. Last time I was researching paint colors, the BRP color codes were available by various paint manufacturers. Typically, the body shop gives the paint supplier the color code, and same as buying house paint at Lowes, the computer adds the exact amount of color to give a matching paint color.
Most important is you are ok, the paint and refinish work looks pretty straightforward. If the trailer structure is ok, maybe just Krylon to match until you save up for a matching color coat when repaired. The Krylon will be wiped away with solvent.
