That is why I like to screw in the bolts for the tupperware by hand. I don't get when people place the bolt on the bit, jam the bolt in the hole and pull the trigger on a power tool. That's a great way to cross thread .
However, I use a power tool to take them off.
OK, not meaning to diss anyone and not being a smartass but a little something to help... When using a tool to enter a screw the essential thing is to keep the screw thread at a right angle to the nut. Unfortunately we have arms, wrists, hands and fingers which are bendy: keep an imaginary line from the elbow, through the wrist and hand and into the driver and screw and rotate wrist and forearm without any misalignment. No wobbling, no holding out of line or any angle but 90 degrees. With a power driver the same rule except in a drill type because of the offset you need to keep the chuck centreline parallel to your forearm.
Good quality fasteners have proper thread form lead ins and seldom require the precision you mention....
I’ve got some news for you, Peacekeeper..........I don’t even use a power driver to REMOVE the panel bolts, let alone tighten them, and I have still cross threaded a couple. I certainly don’t “jam the bolt in the hole and pull the trigger’, as per your rather significant assumption as to the cause of cross threading. I guess I’m just not as smart as you, eh? Oh well, I can live with that. :2thumbs:
Yes, well, judging from the admissions in this thread, perhaps they do. There's no substitute for good technique imho.
I worked at a tap and die company for many years, seen a lot of stripped threads. The bolts that BRP uses on the handle bar mount have loc tite on them.
The bolts are junk and the heads are soft so they strip out easily. been there done that.
