SpyderAnn01
You are correct only the F3 and 20 RT have regular, easily removable bars. It’s a big project on your RT. Good luck!
I too have used an impact driver and allen key socket.
First I'll state that I have had a food machine repair biz for over 40 years and had to deal with way too many seized, stuck, frozen and corroded fasteners.
BRP set you up for this as they are to generous with Loctite. Here's how I'd deal with your problem....
+ Place a punch that just fits in the allen recess and with hammer, give it a few whacks.
+ Loctite will soften with heat - if using a torch be super careful you don't scorch finishes surround the bolt. Could be a hair dryer might suffice.
+ It can't hurt to put a good penetrate in the hole - not WD-40 - Liquid Wrench, or PB Blaster in that order of preference.
+ I hope you have an allen socket for this step; place the socket on a wrench handle (non ratcheting is preferable) and tap the handle with a hammer.
+ If the above doesn't do the job, then it's time to drill the thing out, but you REALLY need to know what you're doing.
+ In the future, when removing fasteners that fight back, use the above steps.
I believe the best solution is hammering a torx socket into the stripped allen head. Apply some heat to the socket and it should come right out. The most painless solution.
You could just leave it and find another way of attaching your stuff...
Here's a trick my dad taught me.....
Have a good, sharp center punch and put a good size dimple onto the head of the bolt near its edge. Then, with the punch in the dimple, lean it to the right and smack it with a hammer so as to move the bolt in the counter-clockwise direction. I'd warm the bolt first to soften the loctite.
