I know that most riders come to a trike from a motorcycle. The learning curve is pretty steep. Having gone thru this in '06, I was wondering if going from two wheels behind to two wheels in front has a similar learning curve?
From reading on this forum, it seems that the tire wear on a Spyder is more like that of a motorcycle(my pre-trike rides were a Road King, an Ultra, and a Road Glide), than a standard trike. The real world service intervals for the '14 1330- 3cyl. have yet to be discovered.
Now that the trike platform seems to have been addressed, what is BRP doing to assure a transformation @the dealership level??
Thanks
Mike
Mike
If you have been riding a GL1800 trike, you will have little to no problem with moving to a Spyder. Both require a light touch to avoid the twitches.
You mention going to the SE6 tranny. That would probably be your biggest change, the "SE" part. If the 2014 Spyder isn't different, then you will find that you don't roll off the throttle when shifting just hammer that paddle and go popping through the gears.
I have posted recently about a move I made that was just the opposite of what you are considering. I went from a Spyder RT to a GL1800 trike. There are pros and cons to each machine. The question is,,, when you do your own comparison,,, what set of "pros" about the trike you end up with, will best suit your needs and desires? That's really what it all boils down to.
Here is is a link to that post.
I tried to be very honest about each ride and I hope it is helpful to you.
http://www.spyderlovers.com/forums/...rsus-Spyder-RT&p=689017&viewfull=1#post689017
But if moving to the SE tranny is definitely in your game plan, then a Spyder is your best (only) choice. I personally like a manual tranny and had additional reasons for moving to the Wing.
One small direct bit of advice. If you do move from a GL1800 to a Spyder, then I think you would be happier with the new 3-cyl in the 2014 RT. Especially if you ride two up and travel as much as we do. I always found my 2010 RT lacking in the low end power and torque area. But, judging by your comment about the SE6, then it appears that you have already chosen the 2014. Stay on that course and don't let a good close out deal sway you to the twin. I honestly think you'd be less happy with the twin. The improvements in the 2014 offering apparently closes the gap with what you are accustomed to on the GL1800. Disclaimer: I have not ridden a 2014 RT, and I am only basing the statement above, upon the findings of Lamont and others who have actually ridden the new RT.
Either way, best of luck to you and you have found a great forum to join. :thumbup:
