Netminder
:agree:Considering they are built in my home province and our country!You think they are expensive. Try buying one in Canada. :yikes:
Can't change or add a thing; other than, :agree:I always enjoy the internet bravura of those who bemoan the Nanny, as if it *really* takes away from our enjoyment.
For one, anyone can "trick" the Nanny by adding the stiffer anti-sway bar, better shocks, better tires, etc. I did, and as a result my RS trips the Nanny far later than a stock RS.
But, and here's where I disagree with the complaints, I can't recall a single situation where I hit the Nanny where my dumba$$ *didn't* need it. Meaning, when the Nanny's engaged on me, it's because I was really risking matters going pear-shaped: hot in a corner, inside wheel lifting, the limits of traction approaching. Nanny kicked in, adjusts speed and traction, and returns me to a safe planted stance.
Now, if I was racing my Spyder on a track, then maybe I'd be expert enough to want to go beyond that limit.
But I'm not on a track, I'm on a public road. And while I ride as spiritedly as any of the most spirited riders here (I guarantee that-- come ride with me, we'll have fun!), I still don't want to tempt fate on the Spyder.
The design of any trike is INHERENTLY unstable in extreme cornering situations. A reverse trike is better than a forward trike, but it's *still* a trike. The BRP engineers discovered that for themselves, and realized that at real-world cornering speeds, they could apply technology to help safeguard against this instability... and, as a result, make the Spyder BETTER performing than other trike.
People who believe the Nanny limits the Spyder's performance have it all wrong-- without the Nanny, you wouldn't be able to push the Spyder as far as you do! Ask anyone whose ridden a conventional forward trike how much "fun" it is not having traction and stability control in the twisties, and compare that experience to the Spyder.
Just for giggles, BRP should have a demo day at the next Owner's Event where they allow volunteers eager to ride a Spyder without the Nanny enabled do precisely that... and have them repeat for the record whether they're still enthusiastic about not having stability and traction control on the Spyder. :joke:
My wife is a nanny, I don't need another one:roflblack:
But seriously, I apparently do not need the nanny, as I have never felt it kick in. I have done some homework on the reverse trike being made in the NL with the GL1800. I've talk to someone who has ridden one and the guy making them. The feeling i get is that you would have to be riding that reverse trike Very very hard to lift a wheel or have the rear swerve out. It can be done if your trying to. I'm not sure how you would compare the other dynamics of each trike, but alot depends on the rider for certain.:lecturef_smilie:
Stability in vehicles is not measured when limits are exceeded (as in too fast through a corner), they are measured in normal flight regime (oops - cruise regime)
A 2 wheel cycle is not inherently unstable in a turn at speeds up to the limit, because it achieves a balance in turn and does not try to diverge from the turn or unseat the operator unless the operator induces the divergence, or one of the constants is disturbed (by an oil patch or change in the turn radius for instance).
A forward trike will diverge from a constant turn by exhibiting gross understeer, and lateral instability of the passenger compartment (tendency to fling operator off) at all times. Having to lean out of the vehicle axis is a sure sign of instability. What if airline passengers had to lean ? What if airplanes couldn't bank a la Spyder ?
A motorcycle does not understeer. And it holds the operator in the vehicle axis. Sportbike drivers who 'lean off' are just playing games with stability.
Granted, a forward trike will resist divergant factors like an oil patch better than a bike, up to a point. Problem is, this may induce you to crash at a higher speed.
Whew. my BS generator just blew a fuse..
I paid $22,000 plus $650 for shipping in an enclosed trailer from a dealer in Texas to my home in South Carolina for a new 2012 RT Limited in September of 2012. I think I got a good deal compared to the MSRP of almost $30,000. My local dealer wanted $25,400 for the exact same Spyder.With possible competition waiting in the wings, i.e. Arctic Cat, Polaris, Honda, et al, do you think that BRP would lower the cost of its Spyder line?
I don't need to state that Spyders are expensive. Do you think the competition could bring a lower price point to the table? I realize that technology such as ABS, the nanny etc. cost money. Do you think a Spyder is fairly priced in the market place given it's the only game in town, for now... :chat:
:shocked::hun: We're not in planes... What "counterintuitive" circumstance are you referring to? I steer right; it goes right... it works pretty well to the left also.I stomp on the brake; it stops... If I even swear a little, it stops faster!It is interesting that in an airplane, if you dont bank ( lean) the airplane will not turn even with full rudder deflection. It is also interesting that raising the nose of an airplane will cause it to descend, not climb. These are counter- intuitive. Lay persons understanding of stability may be based on intuition therefore wrong.
