Does anyone know if BRP has a testing facility in the southeast or southwest ,U.S.A.??Harley tests their new motors at a test track in Arizona under all air temp extremes......I wonder if BRP did the same with the SPYDER/ROTAX cooling system ???From all the complaints and concerns about running hot and from my own observations ......the current production cooling system is borderline sufficient when the air temp is below 90 and you are not stuck in metro area stop and go traffic.When the temps hit 90 plus and you are stop and go.....keep your fingers crossed cause she is getting hot!!BRP really needs to address this issue and future test their cooling systems efficiency in the desert!!I am lucky I ride in a pretty much rural area but when I drop in to the city heat starts cranking up pretty fast....this is a negative for the SPYDER.
Brake Squeel, air box oil leak, and weak cooling system......
other than that THIS TOY is fantastic!!:yikes:
